Talbachi
So, to make a short story endless, bought this ski July 2019, ran ok, but had bad cavitation if 2 people on it and took forever to plane out. Still was able to have many fun days on it. I ride at about 5500 to 6000 ft above sea level in Utah.
I have since then now put a new impeller(Solas 14/22 and the recommendation of Impros) and wear ring, the one it came with was beat to crap... not from me. I have rebuilt the carbs with OEM, old filters were almost all plugged, and have a pop off pressure of 33. Low speed jet is 62.5(should be 70) and the high speed jet is 137.5(should be 142.5)...I assume it had a jet change from previous owner to compensate for altitude.
I have also replaced all the fuel lines.
I have had 3 test trips to the lake, 1 hour drive one way... all three times runs like junk. If i full throttle it dies(lean?). I can get it up to speed if I pull the choke 1/8-1/4. So its obviously running lean...which is not good. Idles great at 1500RPM, but just is so so slow. I grew up riding a 98XP of my bro-in-law so i know what this somewhat should be capable of. I cant even spin a donut. High speed adjuster is out 1/4, Low speed is out 2.25 and still not getting enough fuel. I'm 95 percent sure that all the carb passageways are clean, and accelerator pump is also working great. Ski still has the stock air intake and everything else is stock other than the carb jets.
I'd like to avoid buying new jets but realize that may be my only option. I pulled the RAVE valves today and they were pretty gummy and lots of deposits on them, probably haven't been cleaned in 10 years...got one cleaned out so far, the other will be after work today.
I have not yet tested the compression of the engine, need to borrow tool from brother in law.
What other suggestions do you all have that I should do to get this running decent. I just hate that its a 3-4 hour trip just to test in the water...
Thanks everyone.
Thanks everyone.
