Evening all, I'm after some advice on diagnosing? The issue I have is lack of drive/thrust the ski was running fine no issues then like a switch just revs but very low thrust forward? I've had the jet drive off and the wear ring is a little out on the outer gap than spec should be and after reading this could be the problem but I wanted to know if there was anything else in the drive line that could slip like the pto is it fixed or does it have a cush or clutch drive inside?  Engine is the white 787 and has this pto on the back of it
Any info greatly appreciated!
