Good evening all, I recently picked up a 97 Sea-Doo GTS with the 717 engine from a co-workers dad. it sat in his shop for about 3 years, so I replaced the all of the Tempo lines and rebuilt the carb. I'm trying to set the needles but seeing conflicting information, so hopefully somebody can help. In the shop manual it says to set the low speed screw 1 3/4 turns out and not to adjust the high speed screw, but doesn't say what it should be set at. I've seen 1 1/4 turns for the L.S. and 0 for the H.S. in many forums but most sound like they are running twin carbs. Seadoosource.com says it should be 1 turn out on the L.S. and 1 1/2 on the H.S.
Side not: has anyone ever got an engine from seadooengineshop.com? Pretty sure the inner crank seals are bad, oil will pour out of the exhaust after it sits. I installed a shut-off valve in the supply line just to keep the tank from draining for now but thinking about getting one of their premium 717 engines for $900 this winter and putting in. The fact the offer a 2-year no fault warranty is kinda the selling point on it to me.
Any and all help is greatly appreciated!!
