I have 1997 GTX Seadoo. While riding it last week the engine would suddenly stop. When the engine stopped it was at different power setting, high speed, low and idle. When the engine stop I also last all power to the gauges, it was like the ignition safety lanyard was pulled off. I could get electricial power back by pulling the lanyard off and pushing it back on. I made sure I had good contact to the safety lanyard switch each time I reset the lanyard. This problem happened 5 times in 2 hours of operation.
I did some troubleshooting my self ( I'm certified aircraft mechanic) I used my volt/ohm meter and check the start and safety lanyard switches for: proper opertion, intermittant "opens"and loose connections and chaffed wires-none found in the circuts. Could my problem be in REV limiter? or some other circut in the MPEM?
Thank you
Thank you
