My ski is having cavitaion issues when it hits 5000rpm. Happens everytime at the same rpm. I just took the jet pump and driveshaft out expecting to see a problem and everything looks good. The wear ring is well within specs at about .015 being the widest gap and just a few scratches. impeller looks new. The carbon seal and sealing washer look smooth with no noticable wear. I was not getting excessive water in the hull. The driveshaft looks good with rubber plugs in each end. The plug at the pto end is a little worn. Any Ideas as to what to look for or check?
