LawrenceBMX2
I have a 1997 GTi that I pulled the fuel sending unit out of the other day. Performed the F1 fuse mod thing by removing the fuse and soldering across the terminals. After this was completed, I was getting a reading of 0.2-88.6 ohms. I Plastic welded the opening cut in the sender tube, sealed with seal all, waited for six hours to cure and re-inserted in the fuel tank. Also, while the sending unit was out I removed the float to make sure both magnets were attached (which they were). The float is the newer (I believe) white float.
After the sending unit was re-installed and everything connected, I again checked at the plug and MPEM for resistance. At each location I was getting 36.9 ohms, leading me to believe the float is actually floating. This also seems logical since visually the tank is slightly more than half a tank.
Also, I am getting 12V at the gauges (purple and black wires) and the fuses were just replaced with new ones (just to be sure that wasn't the issue for some reason). I'm still not getting anything on the fuel gauge. The light comes on for the oil light when the key is inserted at start up and as of today when I took it out the speedometer is working. Anyone have any ideas on fixing the fuel gauge from here? I'm pretty baffled.
Thanks for any and all input
