1997 gsx wont go full throttle backfiring
butch30
hi guys,, i recently had my ski out on the lake.. ran great for about an hour..
i pulled it up on the trailer so i could drop my other ski in a 1989 sp.. i know its old and ugly but it still runs.. anyway i forgot to put the plugs back in the gsx. so it filled up about a 1/4 to 1/2 way up inside the ski. the problem I'm having is when i push full throttle it runs fin for about 5 sec then starts back firing. things i have done since the incident. pulled plugs out and crank over engine. put new plugs in. ran ski on flush for about fifteen minutes in idle.
cleaned rave valves. please any ideas of suggestions would be greatly appreciated .... thanks josh
Open the rear box and vacumn the water out. Hope you previously greased all that.
one more thing i forgot.. when i shake the tralier or the jet ski when the ski is running it will stop the motor.
yea good call rear box was full of water.. im going to let dry the rest of the way out.. and see what happens .. is there some type of grease i should put on the componints.. thanks
PROPper maintenance of the electrical system means disconnect, clean and Liberally
aply dielectrical grease. This prevents static electrolosis corrosion = failure.
The fuel circulation system aluminum parts like carburetors & selector valves need painted, then White Litheum grease also applied liberally as a flake, ding, chip, off of
the paint, Moisture will permiate thru the walls aluminum oxide into the circulatory
fuel. The oxide is positively charged. Oil gets into the circulatory from the pulse line.
The fuel mix breaks down both the oil and tempo fuel lines, and is negatively charged. When ski sits dormant the circulated mix settles, canserizes into globs and
the oxide acts on the oil resin like a hardener. Changing the lines and four screens
cleaning the carbs & selector will keep the motor from running lean and premature failure. Grease is the best preventative, many sprays are available. Bills86e
To REPLACE FUEL LINES
Tempo fuel line was used on all skis from 1994 thru 2002. Seadoo 587's-717's = 25'of 1/4"fuel line. Replace the aluminum Selector Valve with a plastic valve to eliminate more Aluminum Oxide from the circulatory delivery system.
First, remove the negative battery cable from battery then siphon and empty any gas from tank.
On 587's, 657's, & 717 skis, cut the new 1/4"I.S.dia. gas line one piece 12" long, two pieces 24" long, two pieces 60" long.
Remove the fuel selector valve by pulling the center plug of the fuel dial with a needle, and remove the phillips #2 screw,
and wiggle & pull until the knob pulls off. Then unscrew the 22mm plastic nut, washer, and push it thru the hull, into interior
compartment. Next, under steering and in front compartment, useing a 10mm ratchet wrench, remove the nut on top of the separator
filter's bracket to free it. Cut all the old fuel lines about 2" away from each part, and set aside. On top of the fuel tank is
a four line bafel top. Look for the vent line and pull that up and off, it probly will come easily. Make a mental note of the
zip ties to the lines as you will tie everything secure from bouncing around when you are done. Next, cut the three remaing lines
2" above the bafel, and pull them up and off as well. Next, undo the two rubber strapes holding the gas tank down in its position,
then unclip the fuel bafel two wire electrical connector. Unhook starboard oil tank strap. At this point you could attempt removal of the bafel from tank,
Inspect the fuel separator/filter O-ring and gas tank vent one-way check valve. Remove the gas tank fuel bafel and clean the Bafel bottom filter/screen,
this is the most overlooked filter in the fuel tank delivery into the fuel circulatory system. When clogged can overwork the drawing power of the carburetor fuel pump. Any Goo from deteriorated lines is immediatly recirculated into the outgoing fuel supply line. Any tubulented goo drops to bottom of the bafel when ski sits.
or wait and grab the emty gas tank from frontside and remove from the ski thru the compartment hatch, and you mat be able to manuver
it out along with the tank as a unit. Remove the Bafel by loosening the lower gear clamp and pulling the bafel up. A circuit board and
a float with a magnet on it is inside the bafel and sends a signal to the MPEM and gauge as to the fuel level. The bottom of the bafel
has a clip/screen, you should remove and clean, and look at the short and full lenth fuel straw in there. The one that is at bottom
where the clip/screen is, is the RESERVE. The one thats about 1 1/2" short is the ON straw. Mark the On & Reserve spigot tube at the
top of the bafel on each tube. Even draw a circle front of the tank bafel with a majick marker of the two wires and four tubes. Mark the O & R on
your drawing, the two other tubes, one is a vent line connection, the other is the fuel returm line from carb & returns unused fuel to tank tube.
Remove the Carburator Air Box to gain access and remove the supply and return fuel lines from the carbs, and discard them. Next, clean
out the fuel tank (use a rag swab on a slim rod) Clean the fuel bafel, disassemble the fuel separator bowl and filter and square O-ring
and clean with soapy water. Clean (if yours has a disassembly screw) or replace the fuel selector switch. Next, useing a helper to lift on
the Oil Tank, slide the clean tank with bafel installed into position and secure the two straps on the gas tank and starboard side strap of oil tank.
Next, look at the fuel selector switch and push the two 2 ft new hoses on the ON and RESERVE nipple and the 1' hose on the unmarked or "fuel out"
nipple and secure with Oetiker clamps, 7 1/2" quality zip tie (TY-RAP) on #4 screw clamps, the three installed hoses. Majic mark the open ends
of the ON hose with an "O" and "R" on the reserve. Push the open end of the short 1' hose onto the assembled separator filter "in" nipple and
secure. Install the 5' hose previously cut on the arrowed "out" on the separator/filter as the supply line to carburetor. Next, remount this unit
first back onto the hull bracket, lines faceing front, and then selector to hull, and secure both. Look at your drawing on tank and bafel and
attach the O to O, and R to R. Next apply air pressure to the old vent line,and if it escapes out the starboard vent hole that is just below the
outside bumper, the check valve and line are OK and re-useable. Apply same to vent at the front compartment latch to check that line and valve.
If it vents the pressure out the S/b same hole, it is OK also. Connect vent line to either bafel nipple and secure. Route the supply fuel line
so it goes in front of the gas filler hose, then back thru the Black multi-holder, then to front carb. Cut a 5' fuel line and attach and secure
to the fourth bafel nipple, and route it next to the supply line previously ran, and route it to the rear of carburetor. Reconnect the electric
bafel wires. Next, useing ZIP-TIES, secure just barely snug, all lines and wires, insureing clearance of front compartment basket. Next you are
ready to put gas in the tank and purge the fuel delivery lines of air useing air pressure applyed into the rear carb return hose, and with fuel
cap on and fuel selector at ON position and then in the RESERVE position, insureing the fuel routes thru the supply line. Gental pressure applied
several times will net the desired gas flowing results.For the carbs to work, you have got to have the flame arrestor on. This is what creates resistance, along with the manifold pressure created by the compression of the engine, to get the gas to the motor. So, if you don't have the flame arrestor on, you'll never get fuel to the motor.
A plastic fuel selector valve is preferred over an aluminum because the aluminum can Oxidize if unpainted & marine greased, from moisture permiation and results in a common corrosion, mineral coagulation and electolitic accumilation, & saltwater mineral electrolosis charge to to fuel chemical mix, that make the heavier oil cling together and drop to bafel bottom, or anywhere in the circulatory system when the ski sits.
Use of White Litheum Grease brushed liberaly on the Aluminum Carburetor(s) stops permiation of moisture thru the metal. It lubricates the linkages & cables thereto attached. Use of Stabile or Seafoam as and additive in the gas, along with a small amount of Injection Oil will help unavoidable contaminats from damageing the fuel delivery system, such as rust from fuel suppliers
the fuel float magnet oxidation, carburetor internal steel part oxidation, and chemically reduces the size of the moisture molecule, which helps fuel flow delivery system componets.
Use your Pop off tester to check the IN & OUT directional air check valves in the breath line attached to Bafel top nipple, up to the hatch "in" vent and rub rail "expell" vent . They should open and allow air flow at 3-5 lbs psi. if the fuel tank pressure release check valve in the OUT vent line thru rub rail is not functioning. The fuel pressure in the tank overcomes the spring tension on the needle valve and gas is FORCED past it and goes into lower case,
causeing over-rich condition resulting in hard starting and poor performance.
HOW TO ROUTE/PURGE FUEL SYSTEM LINES
Listening closly, Open gas cap in case any pressure is in there, then re-tighten. Remove the gas supply line from carb
and put the hose end into a catch bottle. Remove the fuel return gas line from carb nipple and blow a small amount of air chuck pressure into return line. Watch routeing fuel flow easily from
supply in a bottle, IF it routes good, the carb is faulty from a clog or pump diaphram has a hole.
Check pulse tube for clog, it operates the fuel pump with a push-pull or suck-blow as pistons
go up-down in engine case, that is how the mag carb pump actuates route pressure thru the carb, and back into gas tank . A WD-40 straw works good for that. Attach a 2'short fuel line to the tube and if you can blow into the crank-case, its clear of debris.
On dual carb systems, when the mag carb (it gets fuel first) clogs and the PTO carb starves as a result, and that cylinder runs lean, then seizes first. Running lean can cause Glow-plugging and the engine will Rev run-away. Pulling off the lanyard will not help. Asphyxiating by pulling choke and opening throttle may stop engine run-away. Pulling spark wires may injure you and not kill engine as its getting fire from burning piston carbon or red hot spark plug.
Any SeaDoo or other jetski with OEM grey tempo fuel lines will need the entire fuel system rebuilt due to known problems with internal fuel-line deterioration & resin goo clogging up the small internal carborator filters, fuel selector valve and most other fuel system components. Symptoms also include engine bogging at higher speeds (3500 rpm). Continued riding will cause carbonizing & a burned aluminum pistons and engine failure due to lean fuel/air mixtures and high combustion temps. The only solution is to replace ALL the fuel lines with standard automotive NAPA lines, clear race Fuel lines like: http://fuellines.biz, or equivalent, rebuild the carborators with Genuine Mikuni OEM rebuild kits,new needle & seats, and replacing the fuel selector valve. It is suggested to install a clear glass marine grade inline fuel filter just before the carborators to catch any remaining debris, and do a pre-ride dump of the water separator fuel bowl.
Inspect the fuel separator,filter,square O-ring and gas tank vent TWO one-way check valves, that open at 3-5 lbs psi. One breaths air in from near front compartment latch, One expells under the rub rail, if this one clogs or fails overpressure in tank can open the needle valve(s) and leak fuel into a shut off engine. A hard to start occurs and can wear out a starter prematurly. The fuel bafel's bottom removable cap filter/screen if not cleaned recirculates hardened injection oil mineral sludge Goo/debris into the carbs, over & over until the carb filters fail, then bogging occures.
When the Aluminum carburetor & Aluminum Selector valve goes ungreased, moisture permiates Aluminum Oxide thru the walls into the fuel circulatory of carbs, lines, bafel, selector, and separator system. It is estopped by the bafel bottom screen from re-entering the tank. When these AO molecules mix with injection oil sludge, a stopage usually occures at the carb cover fuel hole as a "liquid steel" clog that can only be removed by an 1/8th inch drill bit.
ALWAYS: before starting the engine, remove the seat and look, touch, and SMELL for gas leaks or gas vapors.
Use 7" quality zip ties. I like Thomas & Betts. http://www.tnb.com/ps/pubint/index.cgi?a=get_sub&cid=2 --On my raceing engines I prefer catalog # TY232M, a polyamide & SS ty-rap (zip-tie).
http://fastflowfuellines.com/ I just LOVE the CLEAR line.
http://www.sea-doo.net/Specifications/index.asp Red Stripe USCG approved fuelline by Goodyear Rubber Products is the Best (and most costly) for stock ski's in my opionion.
Gas Tank Breather Check Valves
A common cause of a carburetor needle(s) & seat(s) leaking fuel into the cylinders, wetting the spark plugs and causeing a hard start condition when motor is hot. How can gas get past a needle valve other than what I have talked about? One way is if the fuel tank pressure release check valve in the OUT vent line thru rub rail is not functioning. The fuel pressure in the tank overcomes the spring tension on the needle valve and gas is FORCED past it. The valve should open at approx. 3-5lbs. psi.
Liberal use of Grease on Carbs
Grease on all carb threads during re-assembly will make taking them apart again. If after re-assembly if carb fails the leak down test of holding 5 lbs psi on your pop off tester for 5 minutes. Moisture permiation thru the carb bodies can pick up aluminum molecule oxidants and can form mineral deposits internally and clog the small carb orifaces & filter. Use of White Litheum grease or marine grease helps prevent this electrolitic process. Saltwater adds more electrolosis to the minerals causing them to become potasium cementious. Apply grease also to cables & linkages.
ROTARY VALVE OIL LINES
The two small 1/8th inch id X 6 1/2" long oil lines from the Oil Injection Pump to the two Rotary Valve spigot nipples, have a very short lifetime of 3-4 years, then turn brittle, leak, & break, and is a leading cause of engine failure from lubrication deprevation (no lubrication). Changing these oil lines is recommended every two years.
Hope this is useful, Have a Great Summer. Bills86e
Also, the use of marine grease in your zerk(s), and brushed on the hull intake grate
and componets, impeller,cables, and nozzel will tremendously help pass debris, rocks,
sticks, and just stuff that a jetpump can suck up into it. Bills86e
thanks for all the info.. i cleaned out the rear box and my gsx is running stronger than ever.. at least it is on the tralier.. i do need to replace the gas lines.. i will do that in the winter when im not ridding.. thanks again for all the help..
i wouldnt wait till winter to do the lines! will cost you about 430 and a good day's maybe 2 of work. it will be well worth it!! your carbs are probably clogged, or close to it, and you may no think so as it runs good. This was my case, i was working on another issue and decided to replace fuel lines and clean all, they were horrible and wow what a difference! take Bills advice do it now and spend a day then be down in the middle of the summer
