pfunkmixer
Hello been reading posts for days but can not find my same issue I have 1997 787 gsx bought from a guy who was determined to show me it would start after cranking the hell out of it over and over worried he would burn the starter i told him the carb need cleaning from sitting but he still tried and it started brought home cleaned carbs took it out on the water ran as good as the bad wear ring would let it stalled and hasnt started ever since.get the clunk clunk with the plugs in spins like a champ plugs out.new battery charged even charged car battery was tested, new starter from db electric, applied ground to block with 4 gauge jumper cables and posi to starter post to bypass wiring and solenoid same deal.when turning over with plugs out and apply finger to either plug hole motor imediately bogs down not even covering hole all the way. when turning motor over with plugs out at 15sec interval and waiting 1-2 min inbetween never get anything out of the cylinders oil/fuel water nothing. I do have a hull full of oil tank was full now empty leaked out over a month or two source seems to be line but not 100 percent sure using mirrors cannot see source I read that there is a anti hydrolock port thats always open and if oil is filling up case and overflowed from there I'm at the point of checking case to pull oil from cylinder ports put if its hydro'd wouldn't it blow something out of cylinders or is it possible to have a full case with same symptoms :banghead: thank in advance for support.
