I'm in the process of buying a '97 challenger with the single rotax 787/800. The boat has been sitting in the sun for the past 2-3 years, and needs lots of interior work, the battery is pulled and the air cleaner cover is laying next to the engine. The cover of the power distro panel is also removed, hopefully the previous owner didn't mess about in there too much.
I'm told it was in the water running great before being stored, I'm hoping the engine isn't seized/blown.
It has a hole in the instrument panel below the red start? button. Is that where the ignition cutoff switch would go?
The price is right so its worth it despite the issues. 500 bucks!
Before I fire up the engine what should I do first? Drain fuel tank refill w/new fuel, new battery, check/replace plugs... What else is suggested? I don't think anything was drained before it was "stored", but no freezing temps so lack of winterization shouldn't be an issue unless fuel lines/fittings disintegrated.
Any ideas/help would be great. Thank you!
Lastly, what 2-cycle oil is correct (mineral or synth), and what should it look/feel like?
