Hello, my 1997 sea doo challenger has a significant leak around the "coolant inlet" port on the jet pump. I can see water trickling in around the plastic pipe the coolant hose connects to. There is quite a bit of silcone or caulking around that port, from the inside it looks if the silicone has started to separate from the fiberglass around the hole. Do I need to remove the whole pump assembly to correct this issue or is there a simpler fix? I attached a picture I found on the net, I circled where mine is leaking. It appears they may have a had a similar issue and corrected it by sealing around the entire pump with black "stuff"? What type of sealant would be best to use if going this route? Thank you, any help is appreciated.
