ok i have a 1996 xp 787 with a no start issue.ijust purchase ski from a gentleman who has installed new engine 20 hrs ago.but then it stopped starting and he let it set for 2yrs..when first got ski found had no spark read some articles on this forum and followed the instruction and found failed stator assy..purchased a used one and i now have spark to the spark plugs.the engine spins over fine but does put out a nasty smelling smoke out the carbs when starting..maybe normal 2 stroke smell not sure..oh by the way forgot to say when i got the ski the carb and the carb base was off the engine so i purchased a degree wheel from office depot and install the degree wheel but it didnt line up on the exactly on the degrees described on the repair manual i have it was impossible to do the plate didnt match the degrees as listed on the repair manual it said 146.5 degrees..got it as close as i could..anyway like i said put the key in get two beeps the engine spins over fine but no start (has spark since stator replacement) it at least getting some fuel because i see it on the tips of the spark plugs after trying to start (but have no idea of fuel pressure) even tried to start after adding alittle pre-mixed fuel to the cyds and still didn't start..so at this point iam at a loss i have no idea where to go from here except to maybe try to realign the under carb degree plate it maybe wrong..if you can help me please do iam about to pull hair out..thank you
