Get ready for prediction time!
1996 Speedster - recently rebuilt carbs on one engine and had to replace the tuned exhaust as part of the mounting flange broke off the original one. The boat ran great, the plugs were a lovely brown color when I checked them, and after the work I mentioned above I put about three hours on the boat and it ran perfect.
Took it out yesterday, it started right up, went for about three minutes and the engine I had been working on quit.
Brought it home, removed the plugs and it wouldn't turn over, but it does move a couple of degrees back and forth and goes clunk at each stopping point. I removed the pump, as the wear ring did have a small tear in it, which is new within the past month - not sure when that happened. The motor still doesn't turn over, just clunk. When I try to start it, it just goes clunk.
So, what do you think I will find once I pull the engine and explore? And, what would lead to it running great and dying without warning?
Thanks!!
Thanks!!
