1996 seadoo spx adding mods
Yes the clamp is missing. It uses the one from a stock pipe but not the one you have with the adjustable cone. I don't see the support bracket that mounts the elbow to the mag cover either.
The 1/4" water line will now go to the solenoid that runs the water injection.
thanks matt, looks like ill have to make the bracket. also that clamp, would you have one or @Minnetonk4me would you have one?
is that the bracket i need?
Well I found my clamp tonight but I lost another part lol. About 3 weeks ago I started to clean the pipe, well I took this big o ring out and I have lost it. Any ideas on where to get one? uploadfromtaptalk1461811814004.jpguploadfromtaptalk1461811826746.jpg
It's called "the noodle" although it's not an official term. It's a silicone cylinder shaped stick and you super glue the ends together to make a circle.
well i just got an email back from factory pipe and i got the o-ring. $11 so im going to roll with that. now i just need to make a bracket.
Good advice mandriva.
Glad you got it GL. I was not sure if FPP was still selling those, glad to hear they are. Did they have the bracket or are you just gonna make something?
There are no adjustments on that model. It does everything needed to adjust the rev limit and control the water solenoid.
so i guess i need to just open the ebox and plug and play? I was just a little confused on what to hook it to in the e box. looks line one goes to the ground then the two purple ones will plug in but not sure where the two black ones plug in.
