Congrats - which boat is it in the pictures? I have a 96 Speedster as well, bought it last year. The gas tank (sorry I'm in Toronto) is about 40 litres and that can last just one outting if you are pulling skiers/tubes etc for prolonged periods
Not sure about the oil size, but I only ever fill it about 1/2 full. I keep 10 litres of gas and 1 litre oil in the storage area just in case.
The bilge pump on mine used to come on every 5 or 10 minutes for 5 seconds, even when it was out of the water, that is the way it sensed if there was water to pump out. I changed it last year to one that doesn't need to drain the battery every 5 or 10 minutes. It only comes on when water is present.
This spring I'm installing Trim Tabs (I'm primarily on Lake Ontario) - otherwise it porpoised badly even in minor waves (anything higher than 6 inches). Also installing stereo/speakers and a bimini top.
Top tips from my mechanic:
1. Test pressure every year in both engines (he says anything over 140 PSI is golden) - any significant drop in pressure indicates a more serious issue
2. Always use the exact same oil
3. Don't suck up stones
4. Proper winterization every year
5. Lube/oil etc every spring
Great little boat, fast and fun for the kids - enjoy!!!
