SIMPLEARKANSAN Premium Member Premium Member Mar 29, 2020 #1 I’ve replaced the filter cap, new float, pulled F1 fuse and soldered a bridge. I’ve hooked up my ohm meter and let the float slide back and forth but no change in readings. What else can I check?
mikidymac Moderator Staff member Moderator Mar 29, 2020 #2 That’s about it. Sounds like the actual board might be bad. Did you actually check resistance across your solder bridge to make sure it made contact on both sides.
SIMPLEARKANSAN Premium Member Premium Member Mar 29, 2020 #3 Yes I checked continuity across the solder bridge. It was good. Guess maybe it’s the board.
