1996 Seadoo Fuel Baffle Question
SIMPLEARKANSAN
Premium Member
Premium Member
I’ve replaced the filter cap, new float, pulled F1 fuse and soldered a bridge. I’ve hooked up my ohm meter and let the float slide back and forth but no change in readings. What else can I check?
That’s about it. Sounds like the actual board might be bad.
Did you actually check resistance across your solder bridge to make sure it made contact on both sides.
