My 96 GTX that gives me trouble starting up in the mornings. I have a battery switch installed that I leave in the OFF position when the ski is not in use. When I turn on the switch and give voltage to the ski and insert the key.... it won't turn over. When it sits a few minutes I go back and give it a try... it turns over and starts. I'm wondering if I need to begin chasing wires. The ski did this before I replaced the entire gray box. I am pretty sure I replaced the DESS post. The reason I replaced the gray box was that I could not get the ski to turn over at all. When I replaced the Gray Box the ski started right up. These failure to engage the starter symptoms are part of an obviously existing problem that I did not address totally with the gray box replacement. Input would be appreciated. Every time I check the DESS post with the meter it checks out good. The ski actually sees me depressing the start button because I hear the holder relay clicking.
