Folks, this a 1996 Sea Doo Challenger that is clean and well maintained with the following dilemma. Took it out of the garage first time this season and charged the disconnected battery over-night. Next morning, battery was tested and showed it was full of charge.
Cranked the engine and it turned over about 3 time and won’t turn over any more. Removed the spark plugs and engine cranks and turns like a champ. Purchased a NEW battery and charged it overnight with same results. Once the pressure builds up in the engine after the plugs are installed, engine would not crank. It seems that there is not enough torque to turn the engine over.
Bypassed the starter solenoid with same results. I get the initial 2-short beeps for system = OK.
Removed the starter and took it to a local guy who rebuilds starters and alternators. According to him, the brushes look good, the armature is clean and there is no rust or corrosion. He stated that there is not much in these starters other than the brushes and coil. The teeth on the gear look ok too. No “load test” or clutch test were performed.
Re-installed the starter again and wired directly to battery with no ignition in the circuit and still “no workee”. The starter is pulling over 320A DC! And loading the battery down to about 10 volts DC and below (around 9.5V). Ran the starter on the floor at 5.5A continuous with NO LOAD.
I checked wires from the battery to the starter and they are not corroded but could not check the whole length of the wires on the inside.
The resistance across the leads on the starter are reading like a dead short circuit (0.3 Ohms). I think this reading is through the coil of the armature of the starter.
Any takers on this one before I invest in another starter? Any recommendations on the SBT High Torque starters? Any other tests I need to perform? I’m kind of running out of ideas here.
Thanks for your help…and looking forward to your thoughts and ideas…
