I pulled the cylinders off. They both looked okay from what I could see before, but getting the piston closest to the PTO out of the cylinder was very hard. It looks a lot worse than I thought. And now that the cylinders are off the engines spins freely by hand.
Could it have been the cylinder all along?
Also, to split the case I need to remove the flywheel right? And do a need to buy a puller for that or can I do it some other way.
Without the cylinders and head on, you're going to have a tough time keeping the flywheel from spinning while tightening the puller. You may be able to hold it with a rope between the case and crank web, but I'd probably just put the cylinder and head back on and use the 'ol rope down the plug hole trickI pulled the cylinders off. They both looked okay from what I could see before, but getting the piston closest to the PTO out of the cylinder was very hard. It looks a lot worse than I thought. And now that the cylinders are off the engines spins freely by hand.
Also, don't screw the puller bolts in more than the thickness of the flywheel center hub, or you risk damaging the coils underneath
Using the number on the site. I sent an email once and got no reply. Will most likely go the premium route
