Cheflen
Hey guys I need some help, I'm currently rebuilding a new sp that I just got, and when I got it the crankcase was FILLED to the top with oil, I mean all the way up to the heads. I've been reading all the forums and all of them say it's either the crank bearings or the oil pump check valve. I really don't want to pull apart the crankcase because I'm worried about not being able to time it correctly but if it is the seals then I'm going to do it. My question is, wouldn't it be the oil pump check valve if it's filled this high up? I can't imagine the crank bearings would allow it to fill this high up with oil. If it's the check valve does anyone have a link to buying them? I can't find the part anywhere. It's the white 580
