MightyEsquilax
My first post to the forum! My '95 SP with a 587 is running way too hot. I have great water flow out the back piss holes but the cylinder cover is way too hot and I can't hold a hand to it and the temperature alarm occasionally sounds. I also have a 1996 SP with a 587 and that cylinder cover is only warm and you CAN hold a hand on it. I have some observations and things I have done and a list of things I *think* I should do...but I just need some guidance on where to look next or whether or not I'm looking in the wrong places.
Here's what I have done:
1. I torn off the tune pipe. The exhaust manifold and tune pipe water passages look MINT. No corrosion, no sand, I blew them out with air and water from the garden hose. No blockages that I could detect.
2. I blew out ALL of the water lines going to/from the jet pump and into the engine and exhaust. Same observations, no sand, no corrosion and I feel great air flow everywhere.
Here's the list of what I should do???
1. Validate the Jet Pump Wear ring is ok? I'm pretty sure it is because I have great water flow and great performance from the ski. Not looking forward to the Jet Pump removal...so I'm looking for someone to talk me out of it
2. Pop off the cylinder cover and maybe cylinder blocks to look for blockages? I'm not too scared to do this but I feel the compressed air I've pushed through the lines and manifolds proves there is no blockage...plus the good condition of the exhaust might indicate there likely isn't build up in the engine...? Thoughts?
3. Richen the high speed jet mix? If it were too lean, would that cause the whole engine to run hot hot hot like I'm seeing?
4. Run a compression test?? Would lousy compression in one or both cylinders cause the engine to run too hot?
I'm open to any other suggestions and comments on my TO-DO list.
Thanks for the help!
4.
4.
