jetwrench604
I have a 1995 Seadoo SPI with the white 587 engine. I am having an issue where the only way to shut the ski off is to choke it out becuase neither the handlebar stop button nor the lanyard saftey switch cuts the engine off. I searched this forum and only found a few posts where others were experiencing the same issue.
Troubleshooting I have done so far:
1.) I checked for proper continuity of the wires between the MPEM and the handlebar stop switch when its being depressed. That checked out good.
2.) I also checked for proper operation and continuity of the lanyard stop switch which also checked out good. One other way I know this switch is operating properly is that to start the ski, you must have the lanyard switch depressed.
3.) Checked that all MPEM fuses are good.
3.) Based on these findings, I assumed it was a bad MPEM. I bought the same P/N MPEM on ebay and just swapped it out but it did not fix the problem.
I'm hoping someone has seen this issue before and might be able to give me guidance on what else to try.
Thanks in advance.
Thanks in advance.
