Non of the gauges work. It starts and run great. I've check the fuses and it's ok.
Could a bad Electronic module cause this even thro it starts and stop?
I also had a weak battery and used a battery booster/charger to start it and after that is when the gauges quite working. If that is what caused the problem, wouldn't it take the whole electronic module out instead of just part of it.
I did swap gauges with another ski and the problem is there.
Any help would be very much appreciative.
Glen
Glen
