1995 battery light stays on
water rocket
I also have a 1995 gtx seadoo the battery light stays on when riding an I have a new battery. Seems to be charging fine. can anyone help me on this one
thanks Tony, i have 2 other jetskis with new batteries so i switched them around and im still getting the same problem.
It's real easy. Put a meter on the battery. At 5000 RPM, you should see 13.5 to 14.5 volts. If you don't... something is wrong. (Normally the regulator)
The light should go out if you have more than 12.3 volts. (as I recall)
okay I'll give that a try
