sweaver70514
I just inherited a 1994 Seadoo XP that has been sitting up for the past 10+ years. I put a new battery on it, changed the plugs and decided to try and start it before I rebuilt the carbs and cleaned the entire system out. Once I got the battery hooked up the light to the oil was on, but nothing even tried to start when the lanyard was in and the start button was pressed. Both of these buttons are on the dash. There is a stop button on the left side of the handle bars above the trim. All of these buttons click, but I haven't tested for continuity.
I have pulled the water tight box out and jumped the solenoid and it tried to start. I ordered a new solenoid and did my best to make sure things ended up on the same poles, but I wanted to make sure I got things put back together correctly. Does anyone have a wiring diagram or a picture of the wires that connect to the solenoid?
I jumped the solenoid and the ski tried to start again, but nothing happens when the starter button is pressed. I have test continuity to the starter button and it shows continuity. I am at a loss and haven't worked much on PWC's, but I am pretty mechanically inclined and can walk through any instructions someone might suggest. I appreciate anyone's help!
