Czvas
I am new to this forum, thought I would try and rack some knowledge of more talented Seadoo riders/mechanics
The problem I am having, is about 2-3 minutes after start up, machine bogs right down. Let sit for a day and does the same thing. Im thinking its electrical because Ive done everything in the fuel system, vent system and carbs.
Ive moved onto the stator and done testing
yellow/black to yellow - .05-.6 ohm - in spec
black/red to white - 2.8 - 4.2 ohm - in spec
Black to ground - open resistance - in spec
white to ground - open resistance ---------------- Im getting 157.8 ohms (way out of spec)
black/red to black - 120-180 ohms - in spec
Does this mean the stator is bad? Any ideas?
Also, the rectifier only goes to 13.5v? could the stator cause the rectifier not to charge over 14V?
What Ive already done
- tank pulled, cleaned dry, new float in baffle
- new gas lines/ vent lines
- carbs sonic cleaned and new kits/needle/seat
- new fuel selector
- new fuel selector
