Update to my money pit.
  After a couple more times out last season,  I lost the port side engine.  It locked up solid at the crank. I fogged the engines  and flushed clean water as always. Both engines have had top end work by evidence of jug gaskets.  The very end crank bearing locked up. Looked rusty when i took it apart. I had a spare engine and dropped it in to finish the season.  That was a couple of trips.
  Fast forward to February.  Went to start starboard side, and it was locked up.  Pull the pump, no issues with it. I rebuilt both at the end of the season. Still couldn't turn engine over. Put some oil in the plug holes, hoped for the best for a couple of days,  still no joy.
  Pulled the engine,  jugs, and guess what, same bearing was rusted as on the port side.
I realize that fogging after use is important,  but I wonder if it's my method,  or if it was just time for them to fail.
Both engines are original,  well, they were  before my transplant.  Both engines had the same newer jug gaskets. Can't say if any crank work was done.
If you have read this whole thread,  you can see the boat was a disaster when I got it.
When i fog an engine,  it is the last thing I do. I back flush the engine with fresh water first, then run engine dry for 2 minutes to blow out flush water, then at the end of the 2 minutes,  I  hit it with the fogging oil several times till it dies. Then, I pull the plugs and spray the cylinders.
This is my standard method  after every outing.
Any suggestions,  or we're the engines just overdue?
Just to clarify,  the bearing that failed on both engines  was pto side. The last bearing by the seal.
