Tomrussell
I have a 1994 seadoo gtx that i have recently re-built myself, full engine rebuild, carb rebuild, everything, but the problem i have is i took it out on the water twice and it worked fine, but the 3rd time it bogged down to only running 1 cylinder, so i turned it off for 5 minutes, then it worked again and got me back to shore, the next 2 times i go to use it, it would run fine on trailer but asoon as it had been running for 5 minutes it would go to 1 cylinder and the eventually die alltogether, i have changed the rectifier as i see in this thread some people say its normally that, but still the same problem, could it be the ignition coils failing under load after 5 minutes, has anyone had similar issues and how did they solve it?
Cheers
Tom.
Cheers
Tom.
