Picked up a 1993 seadoo xp the other day has a 657x rotax engine in it. Previous owner had dropped a bolt down the carb and scratched up the rotary valve surface. I got it all sanded down and none of the scratches connected the 2 ports. I put a new rotary valve in be it a cheap one took it to the lake and it ran good for a bit then was started crapping out. Took back apart and rotary valve splints had Ben bent. Bought a oem valve put that in and now the engine almost sounds like it's knocking and not running well at all barely idles and backfiring. Any help is appreciated wondering if I did somthing wrong with the rotary valve or if the engine just happened to blow up in the meantime. Thanks! Link to video
