Yup the Dr. is in the right track. The FIRST thing you should have done is come here. You bought a bunch of stuff for nothing.
Now....the first thing, and the most likely, is the MPEM. Go into the grey box and find the black/red wire (only one with a plastic cover thing) coming off the mpem and unhook it. That disables the rev limiter and the kill switches. Now try it. If it starts, rehook the wire up to kill it. You now know the MPEM is likely bad. From there you can take the kill switch/teather out of the mix by testing, but most likely its the MPEM.
If it doesnt have spark still, make sure the blk/red is still unhooked then you can take the white wire off the coil and put a test light to that wire and ground. Crank it. If it flashes, your coil is still bad. If it doesnt flash, the Stator is bad.
I do have some MPEMs and stators stock if you need one.
