1990 SP Seadoo no crank
ratdoggy
My Seadoo doesn't crank. I jumped the solenoid in the box over the battery and just hear the solenoid click. Is there an easy way to check the starter? I'd like to make sure it's not locked up (the engine) do I have to remove the pump?
When you "Jump the solenoid" on a seadoo... you won't hear a click. You should be using a heavy set of pliers, and jump across the cable contacts. If you do that... you will be sending power right to the starter. BUT... that doesn't necessarily mean your starter is bad. Your cables could be corroded, and yo won't get enough power to the starter to spin it.
The best thing to do is to remove the starter, and check it directly.
