12 Volt low alarm
RJH
Premium Member
Premium Member
my alarm came on charged battery and still same problem. bought anew battery just in case and still same problem.
any direction would be greatly appreciated 2007 RXT215
Thanks I will and give update
Won’t be able till next week
I’ll give an update when I do
Check your 30A charging fuse. It's on a pretty fat red set of wires. If you get the error right away on a charged battery, you may be getting low voltage across that fuse or fuse connector. I had an issue where my fuse connector was getting a bad connection heating up, causing melted fuses. Your connection could be so poor, that you may be getting low voltage from it. I had to get a new fuse holder and metal crip-on connectors to fix it. I never got a low voltage alarm from it though, but was melting fuses left and right. Strangely, they would still work all melted.
Hey Guys
FYI
when hooked up on computer had other codes as well
I checked V.R and fuse blocks all was good
Turned out being loose grounds
