08 C180 2011 Mods
hioctane
Added this year:
- Hydro-Turf
- Added / Upgraded Speakers
- Dual Batterys, New Switch & Fuse Panel
- Depth Finder - The transpsonder included with the Hawkeye wouldnt work anyhwere in the hull so I called Norcross and Patrick suggested I try the upgraded unit and it works perfectly. He said it was only rated to 35 mph but it works up to the max speed of the boat (~50mph).
https://picasaweb.google.com/118393294672562300843/08C1802011Mods?authkey=Gv1sRgCL2ikau-tfX1IQ#
-Scott
Do most of the Sea-Doo models have a location like that for a thru-hull transducer? Is that something I could go to my local Gander Mountain and request a thru-hull over a stern-mount transducer? Or do most of the stern-mount transducers have the sort of surface on the bottom that works for thru-hull applications?
I would like to add some sort of depthfinder or even an inexpensive graph, but don't want to mount a transducer on the outside of the hull.
Thanks for the report. Looks good on your boat!!
I'm not sure which years or models may have that spot in the hull. My depth finder is a D10D (http://www.hawkeyeelectronics.com/). The transducer that came with it didnt work. The one you see in the pictures is their "upgrade" transducer. Apparently the hull is just too thick there for the standard/included transducer to work.
