NPack
Hi Folks,
I have an 07 Seadoo RXT that started throwing a P1502 error code at me. With this code, I get the 2 second beep at start up, the flashing check engine light, and then it will beep at me again every 15 minutes. The ski is also limited to 5000 RPMs, 35mph max, and limited acceleration.
To try and solve the problem so far I've replaced the Interrupter T.O.P.S sensor with a brand new one (PN: 278001992), but I continued getting the code (BTW, if you need to find this sensor it is to the left of your MPEM, below the fuse box). I also checked all my fuses; they're all clean and working (5 A for info center and TOPS sensor). One time I was able to start the ski without getting the P1502 after checking the fuses, but relief was short lived as the ski idled for 5 seconds in the water, then bogged and died. Pulled the key, restarted, P1502 came up again. Pulled the key, waited 5 seconds, tried again, no code but bogged and died again when I tried gassing past idle. P1502 is now back again and I'm limited to the 5000rpms/35mph.
Need help figuring out what to do about this one! Checked all the forums, Greenhulk, this, pwctoday; lot's of people get this dreaded code, but I can't find any solutions! Does the '07 Seadoo RXT 215 engine have a mechanical TOPS switch/valve, and where is it located? Please, this thing is the hardest thing to find in the manuals and I can't find a good test procedure to test if it is good if I find it!
TL
R; P1502, can't clear. New TOPS sensor. cFuses are good fuses. Connections are good. Cannot find TOPS valve. Running out of ideas and summer. Thanks.
TL
