05 Speedster 200 310 HP - HARD START ON PORT ENGINE , DIES AT IDLE
Carguyz
Hello everybody, thanks for taking your time to read my post and maybe help me find a solution to my little issue.
I have a 2005 Speedster 200 310 HP that i bought it about 15 months ago and this year when i when i take it out it seems that the left port side engine does not want to stay running at cold idle so i keep having to give it throttle to warm up the left engine and after a few minutes of low throttle it warms up and will idle without shutting off, it seems like a carb issue but i dont know. if i give it too much trottle is will shut off and if i give it not enough it will shut off...:cool: The right side engine turns on and idles even when the motor is cold, but the left engine really needs low throttle for a good 5 minutes before it will idle without shutting off. Both engines idle at the same RPM so i dont think thats the issue, i'm thinking about doing a minor tune up on it just because it probably could use it but I really dont know whats happening here.
THANKS GUYS
i believe it has around a 120 hours on it (bought it under a 100 and probably put 20 on it)
get someone to run the codes on it, they are the best way to start troubleshooting a computer controlled engine with multiple sensors..or buy a code reader and do it yourself with a laptop
