last summer i was having issues with my ski not running at top speed so i started adding seafoam to the tank to dry out the injectors and this seemed to work. It was running fine the last time i rode it last yr. When I winterized it I filled the tank up and added stabil to the gas. I took it out for the 1st time this yr. and added the seafoam to the gas as well and now it won't even plane out. It bogs starts cutting out at 4700 rpms. It acts as if there is trash in the line and it is clogged up. I cleaned the plugs and then changed the plugs and this did nothing. I pulled out the injectors and they looked ok and it still didnt want to run right. The maintenance light is always flashing also which it did this last yr too. I also tried to crank it with just one plug in and it will crank and run with the back plug in but if i leave just the front one in it wont crank. Any ideas??!!
