Mwhitlock1984
Have a 02 gtx di and during full throttle at 50mph after couple minutes hi temp warning light shows up. It will clear within 30 seconds and can run at 30 to 40mph for 10minutes with no issue or alarms. I also stopped and felt exhaust pipes and nothing is burning hot to the touch, actually feels cool. The engine temp on machine is at 90degrees. No fault Codes on display. Haven't checked on candoo. First time out this year and had no issues b4. Only thing I did was replace fuel pump and new rectifier.
Couple questions.
1. It appears there are exhaust temp sensor and engine temp sensors on the machine. Would both cause hi temp warning?
2. Could a worn wear ring and slightly beat up impeller cause this issue at high end? Thinking not enough flow but no issue last year.
3. Where do you all recommend to start looking for issue?
Thanks
Couple questions.
Thanks
