lmorefield41
I have a 2001 GTX DI that cranks and does not start. I've checked for fuel, spark, and combustion, good on all 3. The pressure was 130/131lbs for cylinder 1 and 2. I sprayed stater fluid into the intake and it starts up for a short amount of time, then dies. I tried revving the throttle after spraying the starting fluid in the intake and it revs, then dies again. It won't start unless I'm spraying starter fluid, which makes no sense because the fuel is being delivered and the pressure is good. I don't think there are any issues with the pump, it hums nicely when I put the key on. I also get the 2 beeps when putting on the key. Any help is greatly appreciated. I'm new to the forum. I received the jet ski from my uncle, he hasn't rode it in 2 years. It was garage kept and he let me have it as it was collecting dust. Had no issues prior 2 years ago when he rode it last. He can't ride anymore due to a bad hip. I put fresh gas in there, changed the battery, changed the plugs, and now I'm looking for help as I'm at wits end regarding what to do next. Thanks in advance!
