I have a 00 Seadoo rx carb and im having a problem with it cutting out at high rpm's i have rebuilt the carbs set them to factory settings the rave vales have been cleaned, the compression is 135 in one and 140 in the other cylinder. I can't figure out why it keeps doing it. Any thing at full throttle and it will cut in and out. Some times I can hit waves and it will hit full throttle but only once in a while. Please I need help!!!! I have been doing a lot of reading and surching but with no luck.
Thank you Casey
Thank you Casey
