Xpl alignment Tool instructions
azsxr
I have a used tool coming but it dosnt have the instructions.
How do I replace the midshaft after
Alignment?
The full instructions would be awesome.
Thanks
You will attach the correct plate to the pump mount studs. You will also thread the shaft support to the plate. Slide in the rod and when alignment is perfect, the rod will slide into the PTO spline end hole without hitting the edges.
