XPDI 2003 Fuel pressure
moary123
hi, i have an XPDI 2003, since i got it i have had problems getting any speed before the warning lamp comes on and goes into limp mode.
i have been working through the manual and found that the Fuel pressure before cranking is 24/25 PSI which is ok, but when cranking it only reaches about 60psi (should be 107 psi), i checked the fuel pump and it reached over 107 psi no problem, so what do you think the next step should be? i was thinking the air regulator may need replacing? i havn't tested the air compressor its self as i dont have the fittings to do so, but i removed the head of the compressor and all looks fine. any ideas?
ok, so what do you suggest? you think its the air compressor or could possibly be the air regulator? any idea where i can get the fittings to test the air compressor?
