Xp limited 951 vts help
Ace875
Hey all,
I've got an XP Limited 951 with a non working vts. Based on what I read online i figured it would be an easy fix with either the solenoid or the motor being the problem. After going through a bunch of trial and error I can't get it to work. The new motor works on the battery and I hear clicks from the solonoid when I hit the buttons. I also flipped the wires to the motor about 5 times. From a multimeter I'm reading about 4-6v at the trim wires when I hit the vts buttons which seems odd to me. Is this low voltage the issue? Any other ideas?
Get rid of it. It’s the electronics in the housing that go bad and are known to fry the expensive MPEM. Contact Westside Powersports Seadoo for a guaranteed tested used one.
