When I first bought this ski it ran fine except for some hesitation on acceleration. The next time i took it out it started to bog down around 5,000 rpm, eventually maxing out at around 3,000rpm and had to be limped into the dock.
I figured the carbs were gummed up so I bought some from a known running ski with no issues, changed the fuel lines and cleaned out all the connectors.
I took it out tonight with the new carbs and a treatment of seafoam ( 1/2 a can on a full tank ). Started off nice reaching 6,500 - 7,000 rpm, but still some hesitation and not hitting that top end power. MUCH better than before though.
However, after 1/2 hour the revs dropped to around 5,000 rpm again and it ran really rough. I kept riding it to see if the seafoam would do the job and it died to 1,000rpm and I limped into the dock. It also sounded pretty rattly and whiny and louder than usual.
Also when I popped the seat there was a lot of water in the hull. Until now it's been dry after a run. Yes the drain plug was in. The only thing I did different this time was use the trim system.
Out of the water it only revs to about 5,500rpm now and is rough as hell. When i changed the carbs it would happily shoot round close to 8,000.
I'm thinking water pump because of water in hull.
The motor has about 135psi in each cylinder.
Any ideas ?
Thanks !
Any ideas ?
Thanks !
