RESTO x4 winter mods / rebuild
TheMachin0
DOO OR DIE
Premium Member
long time coming but its time to fix her back up. bear brown still running strong but crank seals are leaking and it has never charged as long as I have had it together so off to the machine shop for a top to bottom rebuild with premium parts IMG_20141016_073812.jpgI am going to use these carbs and a factory spec1 pipe and a r&d head I will need to find a rotary valve cover because the team butch one I have looks bad I wouldn't even want to try it
questions.
what kind of bearings/seals/pistons ect do you guys recommend
one of my motors has a hot rod crank in it should I reuse parts from it or the stock one
should I use the 95 crank case or a 96 "diff porting"
I have more questions but this is a good start ill also get some good pics of everything
If it was me I would only use OEM crank, pistons, bearings and seals.
I am not sure of the difference between a 95' and 96 case but I don't think there is any porting differences. If you can fine a 97' or newer set of cases they have the balancer oil drain ad fill plugs so that is nice.
95 cases intake tract is a little more open the later ones have a ridge in the intake port [MENTION=57920]racerxxx[/MENTION] has pics of it in one of his threads
Sent from my VS985 4G using Tapatalk
Yep, ports are better on the 95 cases. I believe the 787rfi cases have the same ports as the 95's.
