Well our 1st freeze of the season is scheduled for tonight... 3 - 5 hours of freezing temps, about 30 or 31 degrees is forcast for the Houston Texas area. Concluding my boating is done with for the year, I did the following to my 2006 RXT's 4-Tec engine this afternoon:
1st, I went to Walmart and got 3 gallons of pre-diluted anti-freeze (they didn't have any RV antifreeze, so I just had to go with good aluminum compatible automotive antifreeze... I'll flush it out before going to the lake 1st time next year). While there I also picked up the cheapest 500 gph Attwood bilge pump they had ($17), and a short rv water hose ($8). I cut the hose down to 6 feet long, then warmed the cut off end in boiling water for 30 seconds so I could slip it over the bilge pump outlet (it's a tight fit!).
After getting the hose onto the bilge pump, I added some extra electrical wire to the pump and put 2 alligator clips on the ends so I could hook it to the battery to run it. I then connected the other end of the hose to the flush port on my RXT's jet pump.
I took a clean empty jug and cut the side out of it to make a resevoir large enough to put the bilge pump in, and then filled that jug (with the pump) full of the 50/50 antifreeze.
With a can of fog sitting nearby, I started up the RXT and then activated the bilge pump, pumping the diluted antifreeze in... while that was going on I stuck the straw from the can of fogger into the little yellow fogging port on the 4-Tec engine and squirted fogging spray into it for 15 seconds or so (till the engine went to producing some good smoke out the exhaust). By then the entire gallon of antifreeze was almost thru it, so I added another half gallon to the resevoir with the bilge pump and let that finish going thru the system (green fluid was spilling out the back of the pump by this time). When the bilge pump started going dry again, I unclipped it's power leads from the battery let the engine run another 5 or 6 seconds then shut the engine off.
A good 1.5 gallons of pre-diluted antifreeze when into and thru the RXT's system, I presume that should have flushed out the intercooler really well, put antifreeze in all the water lines and left antifreeze in the exhaust system and jet pump. Thoughts on this? ps. I used the other 1.5 gallons of antifreeze in my jetboats 454 BBC engine using the same bilge pump technique to push the antifreeze into it's cooling system forcing clear water out the transom fitting until it turned green.
As the sun was set by this time, I didn't have time to pull the spark plugs to spray directly into the 4-TEC cyclinders, but it should be freeze-safe at this point so I'll finish the fogging procedure tomorrow.
I read the idea of using a cheap bilge pump to push antifreeze thru the cooling system in another thread on this site this morning, under the SeaDoo Boats forum I believe it was. It made perfect sense to me, so in spite of HATING to go into Walmart TODAY of all days I made the trip and fought my way back to the sporting goods section to get that bilge pump and stuff! LOL!
Where can you actually buy RV antifreeze these days? I was suprised Walmart wasn't carrying it, and neither was O'Reilly's (I checked there too, looking for the pink stuff, but no luck). I'd rather use the more environmentally safe stuff if I could just find it! But oh well, it's done with for this year now.
ps. I had already put Stabilizer in the fuel tank some weeks ago, mixing it in with 5 gallons of gas at a time till I filled up the tank.
- Michael
