Winterizing
rollmagain
I have a 2 stroke that I need to winterize. My first seadoo.
My method was to attach a hose to the water inlet start machine and pour antifreeze through funnel into hose until antifreeze is seen coming out of exhaust. Is this acceptable?
I also fogged and disconnected battery!
That's the way i did mine, did you pinch off your engine drain hose? else the antifreeze will bypass your exhaust system, which holds water as well.
I also removed my water return hose and poured antifreeze into the block that way, a bit over kill , but i wanted to play it safe.
It all depends on what engine you have though? Not much ,but slightly different methods.
Did you fog after or before the anti-freeze? I do it after to make sure that if any got into the engine... it will be expelled.
