I put two gallons of pink antifreeze in a pail with a sump pump connected to the flush port then started the engine, turned on the pump, and ran the engine until the pail was empty. Everything being expelled was pink. After the pail was empty I let the engine run a bit longer while spraying fogging oil in the port on the engine cover. I sprayed long enough to bog the engine as much as possible, then shut it off. Then I pulled the spark plugs and sprayed fogging oil in the cylinders, replaced the plugs, and cranked it over a few times in drown mode.
My only concern is that the sump pump adequately filled the intercooler with antifreeze.
