Hey all,
I winterized my boat last week and something is still gnawing at me. Every year I use a small pony pump to pump a few gallons of antifreeze into the flush port while the motor is running. But I am concerned that I still may have water in the engine.
Boat: 2002 sportster le 951 carb
This year I did my normal routine.
1) Remove flame aresstor from carbs.
2) set up pony pump and five gallon bucket bucket of antifreeze
3) start engine and allow to idle on its own.
4) turn fuel selector to off
5) turn on pony pump
6) Spray stabil fogging oil into each carb easily
7) when carbs begin to runout of fuel full hose down of fogging spray into carbs
8) when engine dies shut off pump
9) remove sparkplugs and spray cylinders generously with fogging oil
10) use small fuel pump to remove all remaining gasoline from boat tank
11) remove battery
12) button up until spring
This method has worked well for me in years past. The question I have is that this year I did not gwt any pink antinfreeze coming out of the telltale pisser below the tow hook. I ran 3 gallons of antifreeze though the system. Am I safe?? I keep thinking about it. I dont want to have to put a battery back in, fuel up, and start the whole process over again. ugh....
Could there still be water in the system?
I have noticed that there does not seem to be as much water flowing out of the pisser when in the water but it runs great and I have had no overheating issues or warnings from the mpem. Could the hose going to the pisser be blocked?
What say you?
11) remove battery
What say you?
