winterizing 2001 gtx di
whimbly1
First time doing this and need input on the propper way to use fogging oil and the location of the port to spray it in. Also, Is stabil fogging oil okay to use?
there are no ports, just unhook the airbox, tilt it back and spray directly into the throttle bodies, you may need a short flexible clear hose to reach the mag side.
all fogging oil is pretty much the same, I prefer bomby lube, seems to stick around longer.
