boatrboy
I just started hearing a whining noise which seams to be coming from the engine side when I removed the seat to listen. The ski has about 230 hours on it and prior owners used the dealer to to maintain it for what that is worth.
When I bought this ski I replaced the bearing assembly for the drive shaft to fix a small oil leak and have used the ski for about ten hours so far this season. I am just a cruiser so I run at about 35-40 mph most of the time without beating it. It has run great but the last two rides I started hearing the noise.
I will admit I did not change the grease in the jet while I had it apart (which now I regret) but the previous owner said it was rebuilt a year before I purchased it.
On the trailer it doesn't sound like it's back where the pump is but rather rear of the engine starboard side where the water lines are.
Does the jet pump noise travel and seem like engine noise? Or is there something common on the engine that could cause this whine?
Any thoughts?
Any thoughts?
